Quad Micro Q-Bot Quad 4 channel with radio adapter problems?
Jay
I purchased a micro q-bot quad with a turnigy radio adapter. I have a turnigy 9x TX I am using with it. I have finally got it binded with airplane setting, but the controls are all messed up. To get the motors to stop spinning I need to hold right stick to the right. Can anyone help me with the settings?
From what you describe, your throttle channel is assigned to the aileron stick at the moment. You need to assign your channels to the correct stick input. Don't know the 9X system to tell you how. It will be something to do with channel mapping. Not much help for you but its a start :) The 9X guys may be able to help with specifics to this radio.
Good luck
