FBL Gyro micro beast
buel williams
just wondering micro beast plus menu F tail sensor direction no status led will not change direction . menu G is not servo centering it is menu H. menu J will not go to 6 dgrees cyclic . could this be a bad unit
Good lord. With all that going on I would say you have a bad unit UNLESS you haven't set up the FBL unit correctly. I Imagine it's not your first rodeo so yeah a bad unit. Especially if you bought it used. Good chance and good luck.
buel williams
Its supposed to be new yet it came without a user guide I used beastx guide for setup. crazy thing is after so called setup everything works correct
fran11784
Its important to know what version your working with as the setup has changed slightly.
From the manual for Version 5.2.
In the left row menu LEDs A and C indicate major version "5".
In the right row LED I lights up which stands for minor version "2".
Cheers
