General Measuring Blades
bigone5500
I want to measure the blades on my blade cp. What is the proper method to use? Tip to hole? Tip to tip?
To measure the blade (on name brand blades that is), you measure from the very tip of the blade to the exact center of the hole where the bolts go. Knock off blades will measure from the tip of the blades to the far end of the root, or the entire actual blade length.
