  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
General Low-wing Vs High-wing Piloting
Discussion in 'Airplanes' started by BCJ, Jan 11, 2020.
< Mounting A Camera | Installing A Xtal ? >
  1. BCJ
    BCJ New Member
    Jul 1, 2017
    16
    0
    1
    Gender:
    Male
    New York
    I've flown mostly high-wing planes to date (with one exception). I just acquired a warbird and want to brush up on flying low-wing planes. I've searched around, without success, for a good primer on the differences between flying a low-wing plane vs a high-wing one. Can you guys point me to the right place? and/or give me your thoughts?
  2. Tony
    Feb 21, 2011
    36,998
    1,444
    113
    A high wing plane will be more stable in the air due to it's lower CoG. A low wing plane will be more agile in the air, but will tend to tip stall easier. This being a war bird, the wing loading is likely going to be higher making the tip stall (turning with not enough air speed) even more likely.
    High wing will also self level, even with a straight wing, although not that well. Dihedral will make it self level quite well which is why 3 channel planes have no ailerons.
    Just remember to keep up air speed and it should be fine. And stay on top of the controls.
    BCJ and Admiral like this.
  3. BCJ
    BCJ New Member
    Jul 1, 2017
    16
    0
    1
    Gender:
    Male
    New York
    Thanks, Tony.
    One other question: I'm setting up a new plane... won't fly til spring. Is there a way I can test out the linkages and servo action without going through the process of binding with my TX?
    BTW, the "Like us on FaceBook" link at the top of your site seems to be broken. I got an error message from FB when I clicked on the link.
    THANKS
  4. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,755
    64
    48
    Norman, Ok USA
    You will have to bind to test the setup...
    I'll also add that when flying warbirds... they have long noses and tend to nose over when landing. So you have to land just so and use your elevator to help keep the nose up. I strongly recommend practicing in your flight sim of choice until it feels natural. It'll more than pay for itself vs having to repair your aircraft all of the time.
  5. Fly-n-Low
    Fly-n-Low Member
    Oct 27, 2019
    30
    1
    8
    Gender:
    Male
    NE Louisiana
    A servo tester will operate the servos if all you want to do is test throws.
    BTW on real aircraft, the low wings usually have more dihedral than high wings because of the CG difference. But then being a warbird, that goes out the window most likely.
    BCJ likes this.
Share This Page
