I loaded cc3d with cleanflight. I have a 250 Quad X
Question number one is :
While going through setup using cleanflight and testing motors it shows in the diagram that the motors are numbered as followes:
RR is 1
RF is 2
LR is 3
LF is 4
But in Open Pilot they had been
LF was 1
RF was 2
RR was 3
LR was 4
So currently my ESC are setup like they had been with Open Pilot
should I now switch them to the way Cleanflight has them
Does that effect how the quad reacts?
Second issue I have is I turned my Board to the cc3d board to the right so the usb port is on the right side of the Quad.
That was how I had it set with Open Pilot at -90.
When I do that in cleanflight the 3d image shows it reversed for some reason. It I set it at +90 it looks right but that can't be correct. Right?
Once again my usb is on the right side of the Quad when looking at the Quad from the back of it.
Any ideas or suggestions. As of now the Quad just flips right away when given a bit of throt.
One or both could be causing this
Thanks
