I think the question was about the least amount of charge rate that can be accepted. If that is the case, there is no low end. It will just take forever to charge it with a cheap charger. I'm running the iCharger 306b which is a 1000w charger and I love it. But this battery can be charged with any charger. If you charge it with a 50w charger, you are only going to get a 4.5a charge rate at 11.1v. But again, that is fine, it will just take longer to charge than doing a 5.5a charge rate.
The big question here is how much money do you have to INVEST in a charger? I did an all caps rage on INVEST because this is usually a one time purchase and you want to get the best you can afford. Not just the cheapest. Which is why I have the 306b with dual PSU's.
And Matt, that is what you get for using an ipad. Invest in Android and you will not have these issues hahahahaha
