Okay, so the receiver is bound and all other controls work except for Aux2. If you scroll the roller to the right, you should go into a monitor menu (from the main screen). In there, find out what switch is moving the Aux2 channel. Does it correspond to the switch you were trying to use? If not, you need to head into your channel assign menu and set your switch to the channel.
