sarconastic
I picked up an old 72Mhz Radio with receiver and servos off Ebay a while back when I was building Arduino Robots and it works great, It a 6 Channel Airtronics with the receiver and 4 servos. Rechargable batteries for the radio and the receiver. The problem I found was that it will not work off the battery packs but will if hooked to an ESC and using the BEC from the S3 battery.
Heres the deal. I built another RC-help trainer from the heavier foam board so the airframe is a bit heavier already, but I would like to build this plane with the larger servos and receiver instead of the micros. Should I upgrade to say a 1250Kv motor to compensate for the weight? I am going center mount the servos just like my other plane to help with balancing. Or should I just compensate by adding pitch and using a 1000Kv Motor. Also will it severely impact flight time for the power required to run the bigger servos?
Has anyone used the larger servos in one before?
THanks
Woody
THanks
Woody
