450 kds450qs
TAZ
Hi fellow members,
I am getting into the rc heli flying.i have got KDS 450qs that my awsome wife bought for me.
i have recently encountered a problem i cant seem to fix.
symptom is heli wont stop spinning anti clockwise.
I have replaced the main rotor head.also replaced the giro with the FUTABA GY520.
Have mad sure all blades are rotating in correct direction.I can manually move rear blades to counter anti clockwise yaw but still wants to yaw.
What the hell.can some one give me some input.
May be your tail compensation is set to the wrong direction. If you push the tail left.. The slider on the the tail shaft should move right and vice versa.. I'd check that first.. Assuming you have the servo correct.
Please note I am not familiar with futaba gyros tho.
Here is a video that Lee has put up.. Hope this helps
Hey Taz, make sure the tail pitch slider is in the centre in normal rate mode (non heading hold), what type of radio are you using?
The video by Lee is a beauty Taz, that's the one that put me on the righteous path of correcting my tail rotor issues. The troops here will get you sorted, the fun is just beginning, wait till you get the little blighter airborne. Enjoy
