  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
380/420 Interceptor 400 Tail Servo Problems
Discussion in 'Helicopters' started by PHIL1234, Jun 28, 2019.
< Swashplate Link Ball And Turnbuckles | "the Big One" Rc Problems >
  1. PHIL1234
    PHIL1234 Member
    Oct 23, 2013
    74
    0
    6
    Gender:
    Male
    Occupation:
    Area walmart
    UNITED KINGDOM
    hi i have problems with my tail servo it will not move at all, all the rest of the servos are moving like they should
    but the tail does not want to move any help would be appreciated as i have never seen this problem befor.
  2. Tony
    Feb 21, 2011
    37,148
    1,458
    113
    Try plugging the servo into another known good port on the receiver. If the servo moves, you may have a bad port or a fractured solder joint inside the receiver. If it doesn't move on the new port, then your servo is likely bad.
  3. PHIL1234
    PHIL1234 Member
    Oct 23, 2013
    74
    0
    6
    Gender:
    Male
    Occupation:
    Area walmart
    UNITED KINGDOM
    CHEERS TONY I WILL TRY IT
  4. murankar
    Dec 4, 2011
    9,230
    388
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    Also make sure your travel limits are set correctly. Another check would be to power the help up and apply pressure to the servo arm. See if vit resists or not. If it doesn't then check it with another channel.
  5. PHIL1234
    PHIL1234 Member
    Oct 23, 2013
    74
    0
    6
    Gender:
    Male
    Occupation:
    Area walmart
    UNITED KINGDOM
    Thanks mate I will try it thanks
Share This Page
