So how would I hook up another receiver.You should be able to use Channel 6 which is the AUX channel, unless your using that for something else ie. GOV
If so run a standard 8 channel Rx and run the retracts off channel 7 or 8 direct from the Tx, that's what I had to do with one of mine with a different FBL controller.
