  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
FBL Gyro Ikon 2 Rpm Getting Slow When Throttle In The Middle
Discussion in 'Helicopters' started by Benoy, Apr 9, 2019.
< Fly Bar Vs Fbl | Align Trex 150x >
  1. Benoy
    Benoy New Member
    Blog Posts:
    0
    Sep 21, 2013
    13
    0
    1
    Gender:
    Male
    Qatar
    Hi,
    IKON 2 FBL Unit. RPM getting slow when throttle in the middle. Any solutions please. Calibrated the ESC, made a new model in Transmitter but still the same problem. Any help please. Thanks.
  2. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,211
    1,385
    113
    what is your throttle curve?
  3. Benoy
    Benoy New Member
    Blog Posts:
    0
    Sep 21, 2013
    13
    0
    1
    Gender:
    Male
    Qatar
    Futaba. -100,-75, -50,-25, 0, +25, +50, +75, +100
  4. Benoy
    Benoy New Member
    Blog Posts:
    0
    Sep 21, 2013
    13
    0
    1
    Gender:
    Male
    Qatar
    Hi Tony, found out the problem. I programmed the ESC again and the item # 7 GOVERNOR MODE i made it OFF then the problem ( RPM getting slow when throttle in the middle) solved.
    It was flying fine but in between i programmed the ESC to check for the Governor and put the item # 7 GOVERNOR MODE value to (2) Governor Low. Then the problem stared.
    Lesson learned is what ever you do write it down. If anything going wrong go back and check one by one. Problem will be solved.
  5. murankar
    Blog Posts:
    9
    Dec 4, 2011
    8,722
    356
    83
    Gender:
    Male
    Occupation:
    Soldier
    Eastlake, Ohio
    The hobby wing gov on gov sto is super easy to setup.
Share This Page
