  3. Like Us On Facebook!
    Dismiss Notice
Trucks I Have A Broken Rc Truck
Discussion in 'Cars, Trucks, Boats' started by Orion, Jun 27, 2018.
  1. Orion
    Orion New Member
    Jun 27, 2018
    4
    0
    1
    Gender:
    Male
    nh
    I have a mad man JJR/C truck. I was driving it at a beach, which it should be able to do, and all of a sudden it stopped driving. The wheels turn, but the motor will not drive. I have checked the connections, cleaned out all important areas of sand, and it still wouldn't do anything. I am fairly certain that it is a brushed motor, and i'm not sure if that could have anything to do with it, but I need help.
    Here is a link to the truck:
  2. Tony
    Feb 21, 2011
    34,420
    1,335
    113
    It is definitely a brushed motor, 390 size. My guess is the brushes are wore out in the motor in which case you just need to replace it. But use a volt meter and verify voltage coming from the ESC into the motor. If you have voltage then it is definitely the motor.
  3. Orion
    Orion New Member
    Jun 27, 2018
    4
    0
    1
    Gender:
    Male
    nh
    I tested the connections on the motor, and there was no voltage. I don't have a volt meter so I used a small LED light, and it would not turn on. what should I do now?
  4. Tony
    Feb 21, 2011
    34,420
    1,335
    113
    You should really get a volt meter for testing like this. You can pick them up for very cheap on ebay or amazon or even locally if you have a harbor freight in your area. A lot of times there is a coupon for a free one with any purchase. So if you purchase a $0.25 keyring, you get a free multimeter. I have one and it does the job.
    But if you are 100% sure there is no voltage, then it is likely one of the FET's in the ESC burnt and the only fix (unless you are REALLY good as soldering micro components) is to replace the ESC.
  5. Orion
    Orion New Member
    Jun 27, 2018
    4
    0
    1
    Gender:
    Male
    nh
    I got a volt meter, and I checked, there is no voltage. what ESC would you recommend?
  6. Tony
    Feb 21, 2011
    34,420
    1,335
    113
    That is going to depend on what is in there. Obviously it is a brushed ESC which are pretty cheap. But you would need one that is the same size as the one you have. Not only in amps, but also in physical size. Best way is to search "1/12th scale Brushed ESC" and see what comes up and compare it to the one that you have now.
  7. Orion
    Orion New Member
    Jun 27, 2018
    4
    0
    1
    Gender:
    Male
    nh
    thank you
  8. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,369
    53
    48
    Norman, Ok USA
    LED lamps aren't a good way to measure... they are typically only 1.5v and burn out too quickly and considering that has a likely max output of 7.4v ( based on the lipo ), you may have killed the LED you used to check it with if you had the polarity correct. Which brings up another fact about LED's... they are polarity sensitive. They only work if the + and - are hooked up properly otherwise they won't light up.
  9. tntpoof
    tntpoof Member
    Jan 24, 2017
    36
    3
    8
    Taylor,MI.
    a led would be fine to test a esc voltage.. as long as its 12v there are many or just use a 1157 brake light use bulb socket many chap voltage meters. if you have the space id just use a traxxas xl5 i do think theres xl 2.5 for 1/18 scale and small rc
Share This Page
