  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Trucks I Finally Got My T-maxx Pro 15 Running Again
Discussion in 'Cars, Trucks, Boats' started by Brandon Parker, Sep 6, 2020.
< Now This Is Fast!! | Tmaxx 3.3 Diff Oil/grease? >
  1. Brandon Parker
    Brandon Parker Member
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    Ashland City Tennessee
    Having a slight issue get in the throttle linkage correct so it pulls the carburetor open and close right
  2. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    having a slight issue getting a throttle and linkage right
  3. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    the wheel spin up when there's no throttle input
  4. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    having bit of the issue getting it to idle perfectly
  5. Tony
    Blog Posts:
    14
    Feb 21, 2011
    37,280
    1,474
    113
    Hey Brandon, sorry for the late post.
    The throttle linkage is on backwards. The carb arm should be on the muffler side. You will need to put the brake lever the other way and swap over the linkages.
    As for the wheels spinning with no throttle, it sounds like the throttle is too high or the low end needle is too lean, or both.
  6. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    The throttle linkage is on the right spot the issue I was having his not getting it set right. and getting it to idle was a very high idle and when I was driving it today it du Soleil dies after takeoff and almost full throttle
  7. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    The high speed needle say if it was closed all the way and you do one revolution is that considered a full turn our half of the turn
  8. D.O.G.
    D.O.G. Well-Known Member Goblin 380 Supporter
    Blog Posts:
    0
    Jul 9, 2013
    3,450
    158
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Hey there Brandon. When I had my Savage 4.6, a full turn is a full turn. My savage was 1 1/4 turn. Try one full turn and see what happens.
  9. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    ok
  10. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    It seems like the engine is flooding itself out when I try to start it with a glow igniter on top the engine wants to lock up even when I have a even when I haven't Prime the engine so is it flooding itself or is it the battery for the easy start cuz it is old
  11. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    the nitro engine is loading up and dies when Throttle Punched
  12. Tony
    Blog Posts:
    14
    Feb 21, 2011
    37,280
    1,474
    113
    Reset all needles to factory settings described in the manual and start the tuning over again. You have to constantly tune a nitro engine, there is no one setting that is perfect for all occasions.
  13. rdsok
    rdsok Well-Known Member
    Blog Posts:
    0
    Sep 11, 2011
    1,891
    80
    48
    Norman, Ok USA
    I'm going a little further than what Tony said... The number of turns listed in the manual is the STARTING place from where you start tuning the engine. Each one is slightly different and will have different settings but you need a place to start from. So it's sort of an art when it comes to dialing in a air/fuel mixture. In addition, each day has slightly different pressure, temperature and moisture... so the setting you had yesterday that may have been perfect, will be slightly different today or tomorrow.
  14. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    ty
  15. Brandon Parker
    Blog Posts:
    0
    Jan 8, 2017
    219
    1
    18
    Occupation:
    Raising chickens
    does the low-speed needle look flush on the end of the arm
  16. Tony
    Blog Posts:
    14
    Feb 21, 2011
    37,280
    1,474
    113
    Cannot see if the needle is flush or not. When looking at the low speed needle, you need to look at it from the side. In the picture, you are looking at it straight on and with a 2d photograph, we have no sense of depth (as we would with out eyes). But, going off of the light, it looks like it is a little too rich. Remember, this needle is only used when the truck is idling.
Share This Page
