  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Projects I Am Currently Planning To Build A Glow Engine Fixed Wing Rc Plane. Need Help With Airfoil Shape
Discussion in 'Airplanes' started by CrazyMonkeyFlyer, Oct 29, 2018.
< Hobbyking 30a Programmable Esc Won't Program Please Help | Converting An Old Flight Star 40 To Electric >
  1. CrazyMonkeyFlyer
    CrazyMonkeyFlyer New Member
    Blog Posts:
    0
    Oct 29, 2018
    5
    0
    1
    Gender:
    Male
    India
    I am currently planning to build a glow engine rc plane. I need help with the frame design. What airfoil shape(example: NACA 2412) would suit if i need good thrust as well as suggest me a glow engine supporting the thrust required for the frame as well. I need a payload of around 4kg or less. How do i design my airfoil according to that? And i am looking for good glow engines with more thrust. So suggest me some of those too. Thanks in advance. :)
  2. rdsok
    rdsok Well-Known Member
    Blog Posts:
    0
    Sep 11, 2011
    1,424
    56
    48
    Norman, Ok USA
    I'm really not trying to pick on you and certainly don't want to discourage you from getting into the hobby that is really fun and exciting but... It's better when you are just beginning to start with one of the "bajillion" ( a made up word meaning a whole lot of ) existing designs than to start from scratch and dive into engineering something you don't have any experience in designing. Aeronautical engineering is not something you just decide to do one day without first having some basic experience.
  3. CrazyMonkeyFlyer
    Blog Posts:
    0
    Oct 29, 2018
    5
    0
    1
    Gender:
    Male
    India
    Hello Mr. Rdsok. Well, then help me out with the existing design and an engine that would fit the frame. And i am from mechancial background which gives me an edge to learn things quiet necessarily. So, i am interested in learning things i don't know too. I would be glad if you could help me out both ways. Thanks :)
  4. rdsok
    Blog Posts:
    0
    Sep 11, 2011
    1,424
    56
    48
    Norman, Ok USA
  5. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,149
    1,379
    113
    Randy is an ARF guy through and through, almost as much as he is an AMD fanboy :poke: hahahahaha.
    Airfoil shapes are numbered in the hundreds of thousands. Picking one for a particular task is quite hard especially when we have no idea what the plane is going to be doing.
    For example, here are some questions that came to mind when thinking about this...
    1. Is this plane going to be carrying a payload?
    2. Is that payload always going to be in the exact same place on the plane?
    3. Is this plane going to fly "scale" meaning never going inverted?
    4. Does the plane need to fly fast or slow?
    Those are the 4 that jump out at me right from the start. I know you stated a 4kg payload, but what is the overall weight of the plane going to be? We will definitely need this answer to suggest an engine to use. And speaking of engine, that brings up a whole new aspect to planning this out. As you fly, you are going to burn fuel. With a payload AND fuel burning, you are going to constantly be shifting the center of gravity of the plane. Can you do this with electric? It would take one question mark out of the total equation if you can.
    And to me, this sounds a lot like you are working as a student in a school trying to design a plane to carry a payload as a class project. I have video of a class at the University of Oklahoma doing testing but ultimately crashing in the end. This just sounds like something like that.
  6. CrazyMonkeyFlyer
    Blog Posts:
    0
    Oct 29, 2018
    5
    0
    1
    Gender:
    Male
    India
    I am sorry for the delayed reply Tony. But one concern of mine is i would go far enough to learn aeromodelling as i am already in the field of xcopters. I would want to learn pretty much everything about glow engines and glow engine rc planes. Interest is everything. I can learn things very quickly and as i am from mechanical background i can get pretty much about glow engines. I am already refering books for airfoils and aerodynamics. But i think that a person with knowledge and experience can help me better with aspects that are not in books. I am going to answer your questions but can you help me out with helping me make one. I am ready to spend but i want to learn. As questioned, the answers for the questions are as follows.
    1. Just two cameras one a small fpv and other for the view of ground.
    2. yes
    3. yes . To learn first with a non acrobatic plane.
    4. Not too slow not too fast.
    And as you were talking about the fuel too, i would also like to learn how the CG of the plane changes according to the fuel discharge. These challenges are meant to be settled rather than sitting in the corner and thinking oh a lot of problems, i will not learn this. I have a person who is good at flying planes, so you need to worry about the plane crashing like the school project unless the plane is made like a school project :p I would appreciate your support for making a plane for sure sir. Thanks in Advance.
  7. Tony
    Blog Posts:
    14
    Feb 21, 2011
    35,149
    1,379
    113
    The school project plane (collage level engineer students) was actually built very well. Very good lift on the wing but I think it had a flaw of being too short making it too "pitchy". Was a great project though.
    I can sit here and type out on a keyboard until my fingers are bleeding, but nothing is going to teach much unless you actually play around and build some planes. Don't let that come off as harsh, just stating a fact. I just don't want you to get wrapped up in the text without going out and experimenting.
    Lets start with the payload. Since it is cameras and they are always going to be in the same place, that is a good thing. that means your C0G will not be shifting from 'releasing' a load. So this is pretty much a non point now.
    Fuel, this is going to be huge depending on the size of the plane and the size of the tank. I know nitro, but I have tried to stay away from nitro planes for this reason. Yet I have a 68" Decathlon with a 4 stroke and a 63" F4U Corsair lmao. But I have never flown them. I purchased them because it was a deal too good to pass up. basically, if you have the tank in front of the C0G, when it is full, it will be nose heavy or balanced depending on how you set it up. As you go through the flight, fuel is burned and the nose starts to get lighter resulting in a tail heavy situation. Tail heavy is very bad and makes the plane very hard to control. 3D planes like the Edge 540, Extra 260/300 and so on like to be slightly tail heavy, it helps them flip around in the air as well as hover and harrier. But I digress, this is beyond our scope.
    In a perfect world, you will want the fuel tank exactly centered with the C0G. This way as you burn fuel, you are only making the aircraft lighter and not adjusting the CoG. So try to make it so the tank is right at CoG. I know your next question and that is "how do I know where to set the CoG?"... Yea, that is a hard one to answer as it is different with every plane. On most traditional planes with traditional wings, set the CoG at 1/3 wing chord from the front of the wings leading edge (that was a little redundant lmao). This is only a starting point and you WILL have to adjust later on.
    As for wing style, I would use a flat bottom airfoil shape. These produce an incredible amount of lift which is what you need with a plane like this. Flat bottom is easy to build as well since you can do it on a flat surface and make the wing perfectly flat and straight. No jig required unlike with a 3D plane with a symmetrical wing. As for size of the wing/plane, that is going to be up to you, your wallet, and what you plan on doing with it. I don't have one on here (yet), but you need to use a wing loading calculator to determine what size to make the wing.
    Also, put a few degrees of dihedral in the wing. This will help the plane fly much more stable. Only about 3º is needed. 1.5º won't have as much affect on the plane, but will still help without it looking like the plane was stored only on the wing tips lol.
    Try this. Click on the Store tab at the top of the forum and download the RCH Trainer. I suggest V3, but you can do any of them. This plane has a KFM airfoil design which was popular back in the day when I created these plans, but now is a dead design and I need to update it. Build the fuse and then build a traditional flat bottom airfoil wing. Get some cheap electronics and fly it. Put a payload on it and fly it, adjust the CoG and fly it. If you crash, the most you are out is $3.00 worth of foam board and maybe a $3.00 motor shaft and a prop. This way you can test without risking a balsa build that took hours if not days or weeks. Foamboard is fantastic for prototyping. Give it a shot.
  8. CrazyMonkeyFlyer
    Blog Posts:
    0
    Oct 29, 2018
    5
    0
    1
    Gender:
    Male
    India
    (O.S. 46AXII ABL .46 Airplane Glow Engine w/Muffler)
    This is the engine i am planning to use for my rc plane. Any suggestions on what ARF Body i could use for good thrust outcome and to lift a weight of around 1kg or less.
    Thank you in advance.
    I would be glad if you could explain me how to calculate thrust basing upon factors i would get on the specifications of engine.
  9. rdsok
    Blog Posts:
    0
    Sep 11, 2011
    1,424
    56
    48
    Norman, Ok USA
  10. CrazyMonkeyFlyer
    Blog Posts:
    0
    Oct 29, 2018
    5
    0
    1
    Gender:
    Male
    India
    thank you rdsok. Can you tell me if these could also lift a payload around 1 kg? And should i cahnge my body according to the payload and engine? Please help me out. Thanking you.
  11. rdsok
    Blog Posts:
    0
    Sep 11, 2011
    1,424
    56
    48
    Norman, Ok USA
    I can't tell you... lifting capacity is NEVER talked about in RC models, the issue is how they fly and not what they carry so nothing is mentioned. Look at the top wing selections to find something likely to carry the most weight but you may be pushing it to get an addition 2+ pounds in a .40 class airplane. Example, the Hobico Superstar is a .40 class ( recommends a .35-.46 two stroke ) and is about 5.5lbs assembled... adding 2 more pounds ( almost 1/2 it's own weight ) is going to make something like that fly sluggish at best.
Share This Page
