Prop How I choose motor and propeller?
sadeep
Hello everyone,
What is the perfect motor and propeller for to get 6000g thrust for pusher configuration?
Thank you.
You don't start by selecting motor and prop. You start with the type of airframe and what flight characteristics you want it to meet. Then you look at the wing loading to determine how much weight you can have in the airframe. Next you'd look at what speed and torque is needed for the style of flight the airframe supports. Another ( but not the only thing ) is how tall does the airframe fit so you know what the maximum size the prop can be.
I always recommend when you don't know that information is to instead start with a known airframe that already has recommended components selected. Aeronautics isn't rocket science but it isn't simple either and there are a lot of complex ideas that must be known first before starting on a new project.
sadeep
ok. thank you. My plane weight is 10kg and I find it want 65kmph speed for takeoff. How I find torque it want?
Reread what I wrote... you still haven't got the info needed to make any selection from. Trying to outfit something you have no experience in is not going to have good results. Start with a set of plans that already has recommended equipment since you don't have the proper experience to select it yourself.
