  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Batteries How far to discharge a battery
Discussion in 'Electronics' started by Slobberdog, Apr 6, 2013.
< DS410M chattering/vibrating | LIFE battery or LifePo battery >
  1. Slobberdog
    Slobberdog Well-Known Member
    Feb 13, 2013
    3,470
    138
    63
    Wales
    Guys this might sound dull but how much can I use my batteries.
    I had approx 6 mins of flight today and that left me with 3.8v per cell, I know the low level for charge is 9v and I don't want to get to there again, lol, but am I right when you say 80% discharge would be 3.4v per cell left or 10.2v total
    What do you guys leave in your cells after a flight,
  2. breeze400
    breeze400 Spagetti Pilot
    Jun 24, 2011
    3,527
    70
    0
    Occupation:
    Truck Driver
    Alden, NY.
    I have my low voltage alarm set for 3.6. Gives you a little time to land.
  3. coolgabsi
    coolgabsi Super Mod & DEAL KING!
    Apr 17, 2011
    4,121
    88
    48
    Occupation:
    Engineer
    North Dallas, Texas, United States
    I think the 80 percent discharge percent applies to the mah's.
    So a 2200mah battery, you wouldn't wanna discharge more than 1760maj out of it
    The only way to tell is charge and see how much you put in. :)
    Fly safe!! :) have fun!
  4. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,768
    68
    48
    Norman, Ok USA
    The 80% ( some say 70% ) is for either voltage or current ( mah ) since both are directly related to each other. So you can quickly check where you are with a voltmeter... and then later verify it with what mah your charger puts back into the batter. I slightly favor using the capacity I put back into the battery since it doesn't rely on whether it is under load or not like voltage does.
  5. Lee
    Lee Well-Known Member
    Apr 20, 2011
    8,489
    399
    83
    Occupation:
    Extreme Sports Instructor
    Tarifa Spain (UK)
    Its good to keep an i on both the Amps and the Volts. I tend to set my alarms for 3.5V under load, which means once i land and the battery comes to rest, it will rise to about 3.7V which is a good voltage to end at.
    The 80% of capacity is good to. As Gaba said for a 2200 battery 1760 is the most you will want to see the charger put back in. When this comes unstuck, is when the battery gets older. It will lose some of its capacity, so if you rely on the 80% rule, 1760 back into the battery will be something more like 90%.
  6. Ken Jackson
    Ken Jackson Active Member
    Mar 19, 2013
    1,184
    24
    38
    Occupation:
    Senior Systems Specialist, Building Automation
    Chesterton, Indiana
    I'm still some what confused on this issue. Maybe my charge is cheap?
    I know I have put more mAh back in then the mAh rating on the battery. That's bad right?
    For example;
    4/2/13
    Flight time set at 5:45
    Starting charge volts 3.56 end 4.20 volts
    76.5 Minute Charge Time
    2648 mAh
    This is a 2650 mAh battery. If that's what went back into it shouldn't that battery have been ruined? I took everything out of it but 2 mAh?
    Here's a different battery, different day;
    4-4-13
    Flight time set at 5:50
    Starting charge 3.74 V
    120 Minute Charge Timed Out did not complete
    2736 mAh
    Any help would be appreciated
    Ken:devilish:
    Both batteries are about a month and a half old, both have under 8 flights
  7. wolfman76
    wolfman76 Well-Known Member
    Sep 5, 2011
    2,645
    59
    48
    Occupation:
    basic laboror for the moment till i can find sumth
    hammond,indiana
    THIS IS ALSO SOMETHING I WOULD LIKE TO KNOW AND HAVE NO CLUE ON... sorry bout caps did not realize they were on
  8. coolgabsi
    Apr 17, 2011
    4,121
    88
    48
    Occupation:
    Engineer
    Yeah that seems to be a battery or a charger issue .. A battery that low wouldn't even charge.
    What charger?
  9. rdsok
    Sep 11, 2011
    1,768
    68
    48
    Norman, Ok USA
    Most of the time, a battery will have slightly more than their rated MAH capacity... but I don't believe that is this issue at all.
    I suspect a bad or weak cell in the pack... the charger is trying to balance the pack and in doing so, it must remove extra power from the high cells in order to bring them back down the value the low cell or cells have... and then it replaces that current. One with a really bad or weak cell will repeat this process a lot of times to finally get all cells up to power.
    This type of issue is usually caused by how the battery was treated durning it's life span or by the battery just getting old. Cheap batteries will also do this much sooner than a quality one will.
  10. pvolcko
    pvolcko Well-Known Member
    Feb 12, 2013
    2,421
    173
    63
    Gender:
    Male
    Syracuse, NY
    I'd say you drained that battery too much. Bump your flight timer down to maybe 5min, or even 4m30s. If you do this once or twice it isn't the end of the world (particularly with a quality battery), but if you consistently drain the battery like this it will end up damaging it and shortening its life significantly.
    This start voltage is a little low, again indicating you need to shorten your flight times. I agree with Randy, you probably have a cell way out of balance. Use the balance charge mode and if needed put it through a few balance charge cycles. The charger will recognize the overall charge condition and switch into balancing mode fairly quickly, so you aren't in danger of ruining anything by doing this. Your balancing charger should have a mode that displays the cell voltages, could help us if you report back those per cell voltages before you hook up for another balance cycle.
  11. Ken Jackson
    Mar 19, 2013
    1,184
    24
    38
    Occupation:
    Chesterton, Indiana
    Took me forever to find this thread again, damn. Anyway I only charge balanced and I always look at the individual cell voltages. That 3.56 was crazy low and I was lucky because the ESC was shutting down as I landed. Normally I see 3.76 - 3.78 volts at start. And that is all six cells. I have never seen a cell more then a 10th or 2 away from the others. I had always just looked at voltage, a friend recently told me about the mAh method but as you can see it makes no sense based on what I am seeing.
    Battery performance is consistent. I wouldn't call these expensive batteries but they are decent. Buy these from hobby king for $52.
    Starting charge 3.76 v
    66.49 Minute Charge Time
    2369 mAh
    Start charge 3.99 volts
    28.5 Minute Charge Time
    786 mAh
    the start charge voltage I list is the average of the six cells
  12. Ken Jackson
    Mar 19, 2013
    1,184
    24
    38
    Occupation:
    Chesterton, Indiana
    So is my charger just too cheap??
  13. Lee
    Apr 20, 2011
    8,489
    399
    83
    Occupation:
    Tarifa Spain (UK)
    The higher priced chargers will give you more info about the battery. like the internal resistance. And will have a better balancer. I have 4 batteries that will not balance after a charger damaged them. I'm waiting for a new charger that has the ability to balance them again.
    I have those same batteries as you but the 5000mah ones. If you fly too long then one cell will start to drop of quickly. I had one that was at 3.65 on all cells but one that dropped to 3.45
  14. breeze400
    Jun 24, 2011
    3,527
    70
    0
    Occupation:
    Truck Driver
    Alden, NY.
    I'm still not getting this when I do the math 80% of 4.2v is 3.36. So I figure 3.4 to be on the safe side. Now that is loaded volts not idle volts. Now I have my loaded volts set to 3.8 my warning lights start to flash. At 3.6 volts my NAZA lands. Now remember this is loaded volts. Once the motors stop, the volts will come up some. I'm I right on this or off bace?
  15. Lee
    Apr 20, 2011
    8,489
    399
    83
    Occupation:
    Tarifa Spain (UK)
    The 80% is for Mah not the voltage. I have my voltage set to 3.5 under load, which normally raises back up to 3.7 at rest.
  16. breeze400
    Jun 24, 2011
    3,527
    70
    0
    Occupation:
    Truck Driver
    Alden, NY.
    I'm still confused? In post 7 he says that he put in more mah then the battery was rated for?
    If I can figure out how to use skipe, then we should talk ths weekend! Lol.
  17. Lee
    Apr 20, 2011
    8,489
    399
    83
    Occupation:
    Tarifa Spain (UK)
    Yes, if you look at Craigs post on the first page, he says, a lot of batteries have more Mahs than they actually state on the battery.
  18. breeze400
    Jun 24, 2011
    3,527
    70
    0
    Occupation:
    Truck Driver
    Alden, NY.
    Ok so on my 4s nano teck's, 5000's I can take them down to 1000 mah? And put back 4000mah?
  19. pvolcko
    Feb 12, 2013
    2,421
    173
    63
    Gender:
    Male
    Syracuse, NY
    Yeah, that's the idea. As a quick stand in, take a look at what your battery at 1000mAh left reads as a voltage under load and at idle. It will be in that same voltage area at that capacity so you can then use that voltage as a means of knowing what the remaining capacity is. And, the capacity rating is just a rating. A 5000mAh battery may well take 5500mAh of charge from a "complete" drain. Another might only take 4800mAh. Different vendors are more honest about their capacity ratings than others.
  20. rdsok
    Sep 11, 2011
    1,768
    68
    48
    Norman, Ok USA
    Also remember that if the charger is balancing the batteries... it has to remove power from the cells that are high and then it replaces that power across all cells... If a cell is weak, it won't take as much charge as the good cells will and the process repeats until the weak cell finally has caught up to the good ones.
    You could say... two steps forward followed by a step back... then two forward again and one back...
Share This Page
