hi to everyone been a while now i have got up in the air i feel the need for a governor, i bought an aligng600 and need to know if i can fit it to my heli as it only has 6ch and the only ch left is bat/bind
There is a very small number of options you are left with... I have the same setup.. Governor with 6 channel...
You have to either buy a multigov / multigov pro or I think throttle jockey..
These governors have an option to select your speed through the programmer abd not need a 7th channel.
I have both multigov and multigov pro one on each nitro heli. It's one of the best governors out there!
You will have only one headspeed be it idle up or normal. Honestly that's the only difference.. And you get much more control out of the bird even in normal mode as the head speed doesbt change and is high..
Aerospire makes it.. Look on classifieds of some more forums.. You'll find it for cheap... Aerospire.com has it new. You will need 1 LCD programmer with it though.. 1 is all you need for multigov or pro..
