Hello Tony and other members.
Today I has going to adjust the spring tension on my DX8 elevator gimbal. I removed the rubbers from the back and located the holes on which the screws for adjustments are. I started unscrewing to decrease tension on the elevator and aileron stick, but somehow I missed the hole and put the screwdriver in the "M" hole. I ended up unscrewing the "M" screw and "loosing" it i side the transmitter.
To put it back, I opened my DX8 as per normal and put the screw back. Now my question is: HOW DO I MECHANICALLY CENTER THE ELEVATOR STICK? (Please see pictures for reference)
I watched on YouTube the video "DX8 How-To Pt. 5, Changing The Mode Of The Tx From Mode 2 to Mode 1" and at 3:50 min I can see the elevator stick is off center, just like mine.
Please any "How to"is welcomed.
Thank you very much!
