General HK459gtpro2 measurements
treff
I wonder if anyone has the measurements of the pitch, ail, and ele rods of the HK450gt pro2. It must be the pro2 because it is
different to the gt. I would be most abliged. Thanks
Thanks Slobberdog after much net searching found what I need. My fault kept skipping past the page I needed in the manual Doh!
Still nearly ready for a maiden just finishing off the huge training gear. I hope the heli will lift it LOL these cast iron I beams weight a tonne
Cheers Kev
Thanks danhampson yes the same but thanks for your time. I found that the measurements on the Align drawing do not go with the
HK450gtpro2 so I think it is trail and error. Using the Align measurement makes the swash to high by quite a large amount. Thanks again
go FBL treff lot less parts to worry about and break, get the plus dfc parts and a cheap second hand 3Gx, and you will be laughing. you wont regret it
Thanks Slobberdog. Yes I have been think of doing just that. It is certainly the way to go I think. Looks more robust mechanically and also
more stable in flight from what I have seen. Cheers
