fireman7234
Hello Guys I just put in Flysky fs-r6b receiver in a hk450gt hooked up servos have all been set with subtrim to be 90 degrees to servo body have elevator servo in channel 2 aileron is channel 1 and pitch is channel 6 looking from tail i got the swash plate moving in right direction with sticks left to right but when give foward input all 3 servos move up in the same direction and then move stick backwards all move the same and when i give throttle elevator raises but aileron and pitch lower not moving all the same (throttle is in channel 3 ) ive tired adgusting in the swash afr in trasmitter (FS-T6) nothing seems to help stuck need help
