Hitec Eclipse 7 Pro 2.4 with Phoenix 5 sim
You should be able to go in and set your Tx to the Futaba one, there might be a CP option in there. You will have to go in and reverse some settings in teh program though.
Rajablue
This radio won't let me change the swashplate to 90 degrees, I can set it at normal, 120, 140 or 180. If I am flying heli's I can't lift off the ground. Any ideas?
Thanks
The 90º setting is the Normal setting. It's the same way in my DX9. Have you tried the normal mode?
Rajablue
I have it in normal mode, I'll go back an recalibrate my tx, see if that helps.
Any other settings I need to be aware of?
Thanks for the response.
Rajablue
Tony, Thanks for your help, I was able to get it working. I didn't do the original calibration correctly.
Thanks again.
Sorry for the late reply, they are working me like a dog! lol.
Glad you got it working. Let us know if you need any help in the future.
Rajablue
I have a question for this tx; How do you change from "Expo" to "Expo low rates"? Can you change on the fly while using the sim or what?
Thanks again in advance,
Rajablue
Just go into the Tx and set the DR and Expo in there. That Tx does have those menu's in it, right?
