I have to correct you there. You said "make sure you have smoke"... The correct answer is, make sure you have a LOT of smoke lmao. Best thing to do is check it with a temp gun. You should NEVER exceed 200º, just like with the truck, even though the truck likes to run a LOT hotter than that.
As for "are you capable"? You damn right you are. It's nto that hard, you just need to make sure you get the max power out of it without over heating it. There should be a LOT of smoke coming out of the exhaust, but not enough to where it dies when you hit throttle hold from full throttle.
