General Heli Motor Not Spooling Up
How to test my motor or esc or transmitter tings
  • Sab 280 new build
    Votes: 0 0.0%
  • Esc or trans settings
    Votes: 0 0.0%
  • Total voters
    0
Dano1
I just built a 280 sab Heli and I get no response from my motor just beeping not spooling up . Please help
Sounds like you need to calibrate your throttle endpoints in your ESC. I'm pretty sure the ESC is not seeing a low throttle signal.
As Tony said, also check that the throttle wire from the ESC is not plugged into the receiver/FBL with reverse orientation.
