Usually 2.4 is pretty good at not doing that. When I was racing cars, all I used was Airtronics, but that was back in the FM days lol.
Couple things you can so to test this. First, rebind the Rx to the Tx. You could have had a bind issue although it's unlikely. The only other thing I can think of is where you had your antenna pointing. Never point the antenna directly at the aircraft. The signal radiates out from the side of the tip. Directly off the tip is almost like a dead area. I always bend mine over and lay it to the side.
Lastly, never be scared of it. Just look for the solution and solve it. Use caution though in your next flights. Put training gear on, and see about flying in that arena again by yourself. If it happens, then you could be having an issue with the metal around there. but I would think everyone else would as well. And make sure to do some testing out in a field. I know it's cold outside, but this will give you more answers to your questions.
Hope this helps mousie. Let me know if there is anything else I can do.
