Scale Heated fuselage
Has anyone had a problem with their scale heli getting hot inside the fuselage? I was thinking about removing one plastic window from each side. That should let out some heat. Any idea appreciated.
I would most definitely do that. The electronics need all the air movement they can get.
junior10
i left out all the side windows on my md500 and i think it still has a good look. IMG_0668.jpgwhat fuse are you using?
Thanks guys. I will take out some windos. junior10, I'm using this fuselarge P9020007.jpg You got your self a nice looking bird there!
holtneil
HI mate lovely bird , over heating is a common problem with scale , most of us remove side windows and a few of us if we have room fit cooling fan in side like you would use in a PC they are really cheap $1.30
