claytonbakerjr
I am full of questions today
For the most part we must protect our ESC's from touching any part of a carbon fiber frame.
I will assume the same goes for the ESC's heat sink.
Now then as long as no part of the ESC touches the carbon fiber we should be good to go.
If I were to cut a small hole over an area of the heat sink to help expose it to more
cooling would I stand the chance of an ARC of voltage/electricity getting back to the CF?
I need to change the path of the signal wire on all of my ESC's I just purchased to
help reduce the thickness, currently the signal wire runs over top of the capacitor I am
going to move it to where it runs off to the side.
I also have noticed some ESC's on the market where this capacitor is not covered
with any heat shrink, am I to assume this is a weak point on the manufacturers side or
that the capacitor does not conduct electricity externally and if it touches it will not
burn out the ESC?
burn out the ESC?
