I run my X3 at 3500-37000. Not real sure...LOL. You definitely don`t need it that high. Just play with the head speed, and set it to where you are comfortable with it. As for the throttle curve. I suggest a flat curve. Something like 0%, 40%, 40%, 40%, 40%. The reason for that, instead of something like 0%, 25%, 40, 45%, 50% is so the motor stays at a constant speed. That way, you`re only dealing with pitch inputs and not pitch inputs and the motor slowing down and speeding up. It will make for a much easier hover. Also, if your transmitter allows it...enable pitch expo. That will soften up the transition of the pitch as you move the collective, and take away the "twitchy" feeling when you go up and down on the collective.
One more think that I probably should mention. If you are going to use the flat throttle curves, make sure you have soft start turned on in your speed controller. If you don`t, the motor will start too fast, and tip your helicopter over on spool up.
If your speed controller does not have soft start, or you don`t know how to enable it. Use the second throttle curse I posted, or something along those lines.
With the hobbywing governor being as good as it is I would use that. That's how mine is setup.
You`ll find that a flat throttle curve will help with the yo-yo effect. The DX18 has pitch expo. It`s on the bottom of the screen when you go into the pitch curve menu. It should say (INH) next it, Just change it to enable. and it will set it automatically.Thanks for your suggestions Geena. My throttle curve is set at 0%, 25%, 35%, 45%, 55%, 65%
It's bobbing up and down on me like a yo-yo. I'll try your flat curve. Interesting I've never heard of pitch expo. I have a DX18 and I'll have to check it if has pitch expo. My esc is a Hobbywing, I have to check on the soft start.
On the hobby wing I think it's gov store. Set your pitch curve to 0° flat then set your throttle curve to 50% flat. Spool it up, once it gets to full head speed wait about 30 seconds then hit throttle cut. Unplug your flight pack then replug it.
In the radio set your pitch curve back to the 0 25 50 75 100. Set your throttle curve to a flat 80% all the way across. Your governor head speed will be what ever throttle curve you set. So if the headspeed seems to fast at 80% then dail it back to 75% flat. Orif it's to slow the kick it up by 5% not to exceed 90%. You will need to leave 10% for the governor to use at the top end.
To figure out your actual headspeed you will either need a tachometer or a gyro that can read the ESC telemetry ouput.
I have another problem to deal with now. On this X3, the rudder is pulling to the left. I tried adjusting the gain on the AR7200BX, put in over 20 points of trim but neither helped. Any ideas? Thanks.
