USAF_Ret
I am contemplating acquiring a Goblin 570 KSE and am pondering the motor / battery options and would like to get folks recommendations or how they currently have theirs setup.
So what are folks using and how do they like their setups?
The battery options for 6s are pretty straight forward but the 12s option seems to have a wider motor (kv) battery (mah) range (2600 - 3300 mah). I would also be interested in what brands of motors (kv) and size (mah) that folks are running and what are typical flight times for both the 6s and 12s options.
Are there any upgrade options that you would recommend?
I already fly a Trex 550L , so have a set of 4, 6s, 5000 mah batteries, so from the cost side, going with the 6s setup, seems to be slightly less cost regarding batteries and don't currently have a 12s setup, but have read that there is less motor bog with the 12s setup. I don't currently fly hard 3D, but am learning and don't want to have to replace the motor and get new batteries too as I advance.
I plan on running the IKON 2 for the gyro, if that has any bearing on topic.
Look forward to your opinions and recommendations.
Paul
Paul
