  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
380/420 Gaui X3l Under Construxtion
Discussion in 'Helicopters' started by Admiral, Feb 25, 2019.
< 700 Servo Insight | The Club >
  1. Admiral
    Admiral Well-Known Member
    Mar 2, 2014
    2,090
    127
    73
    Gender:
    Male
    Occupation:
    Information Technology (Retired)
    Brisbane, Australia
    The Gaui X3L that I recently purchase is under way, few delays because of parts, I stripped down a Compass Warp and not all the components that I needed were compatible, things like an ESC I wasn't sure of and a motor with too low a KV rating and a broken servo arm not a MKS servo which has a different spline to every servo arm I have in stock and thats a heap. So I decided to slow the process down and take my time with the build.
    IMG_4136 (Medium).JPG IMG_4141 (Medium).JPG IMG_4143 (Medium).JPG IMG_20190223_083635 (Medium).jpg
    Baz Gascoigne likes this.
  2. D.O.G.
    D.O.G. I Support Rc-Help! Rc-Help Supporter Goblin 380 Supporter
    Jul 9, 2013
    3,131
    135
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Good for you to slow down and take your time. It's not like you don't have other birds to fly. Still the build is looking good Admiral. No need to rush perfection :).
  3. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    I do like those CF flippers. Wonder if they make them for the Goblin...
  4. Baz Gascoigne
    Baz Gascoigne Member
    Jul 8, 2012
    53
    2
    8
    Gender:
    Male
    Occupation:
    disabled
    newcastle upon tyne
    looking good Admiral i like the looks of that Gaui X3L
  5. Admiral
    Mar 2, 2014
    2,090
    127
    73
    Gender:
    Male
    Occupation:
    Brisbane, Australia
    Yes we can see Tony it is very Goblin influenced in appearance but the flippers aren't staying Tony, as I fly mainly on grass they are being replaced withe original skids, if @Geena has trouble with them on grass I'm not going there.
  6. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    hahaha, I hear ya. I just like the look of the Goblin's with flippers. My first flight with this little guy might change my mind. Especially if I have to replace the blades lmao.
  7. D.O.G.
    Jul 9, 2013
    3,131
    135
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    I did the same Admiral. I took Geena's advice too and put the spare skids from the X3 and put them on the X3L Just to be on the save side and save a couple $$$$ if she tipped over.
  8. Admiral
    Mar 2, 2014
    2,090
    127
    73
    Gender:
    Male
    Occupation:
    Brisbane, Australia
    Had a day to myself, all finished except for the new ESC which is on the way I have fitted another ESC to do the setup but will swap it out before the maiden.
    With flippers for Tony, I also like them but...
    As finished with original X3 skids.
    Was a great build, easier than the first because of the previous experience, I think that the only issue for anybody who didn't have a copy of the original manual they would have a few problems as the manual supplied with the X3L is really only the upgrade manual for the standard X3. The X3 manual is available on the Gaui site however.
  9. D.O.G.
    Jul 9, 2013
    3,131
    135
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Glad to see you got her done Admiral. It's looking good. A little heads up, don't forget the X3L is going to be tail heavy, Geena mention. Depending on the battery your using, slide it forward. I'm using a small 1250 mah and I had to add extra weight to level her out. Just a warning.
  10. Admiral
    Mar 2, 2014
    2,090
    127
    73
    Gender:
    Male
    Occupation:
    Brisbane, Australia
    Thanks D.O.G. I'm using a 1450 and have an 1800 on standby in case I need it.
    Trouble is with new technology batteries are getting lighter for the same output.
  11. Admiral
    Mar 2, 2014
    2,090
    127
    73
    Gender:
    Male
    Occupation:
    Brisbane, Australia
    Well I couldn't wait for the new ESC to arrive, after not being able to fly for 3 weeks due to a trip away and 2 weeks of gail force winds common sense went out the window and I decided to maiden the X3L, in spite of a bit of rain and wind, the site was the under cover basket ball area where I normally fly.
    Should have flown up and down the court to save the glare on the video but that would have meant a cross wind and I didn't want that for a maiden.
    All in all it went well the slight tail heaviness that I plan on addressing after the new ESC arrives, did not effect the flight at all but may do later when I'm flying full circuits. Will raise the head speed a bit before the next flight, but it looks great in the air and is stable and predictable to fly, very pleased.
  12. D.O.G.
    Jul 9, 2013
    3,131
    135
    73
    Gender:
    Male
    Occupation:
    Disable
    Inverness,Florida
    Beside the rough start, nice going Admiral. Seem very stable and smooth. I bet you can't wait for the new esc and the weather to clear up so you can take that bad boy out for a real flight. Enjoy the X3l and keep the videos coming.
  13. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    Ah yea, look at that modified pinch! NICE!
    Definitely looked very good in the air, but you really should upload a video that is fresh, not from 2012!!! :chuckles:
  14. fran11784
    fran11784 Member Goblin 380 Supporter
    May 3, 2013
    450
    19
    18
    Virginia
    Nice, and looks like a perfect place for a median. Wind and rain has been the story here too....
  15. Admiral
    Mar 2, 2014
    2,090
    127
    73
    Gender:
    Male
    Occupation:
    Brisbane, Australia
    Yeah I'll have to turn that date off, the glasses don't hold the settings if they go flat.
  16. Tony
    Feb 21, 2011
    37,077
    1,454
    113
    I have some of those glasses so I know the pain. Just had to give you a hard time. Great flight nonetheless.
Share This Page
