450 Futaba T14SG-H & ikon flybarless help
Biglion
Hello to all
I need help with my new ikon flybarless system
and my futaba T14SG-H R7008SB
I Build new trex 450pro dfc
When I finsh setup with ikon software
My heli spin like Celine fan
And I told them in futaba throttle and pitch ara must
Be reversed
I wroth to ikon customer support and
Thet what they told me
Any help will be find
Thank you
Sales Representative
Email sales@ikonflybarlessc.com | web Welcome To Ikonflybarless systems
On Tue, Dec 30, 2014 at 5:00 AM, Eyal Kadosh <Eyal0375@zahav.net.il> wrote:
Hello my name is Eyal
I have the ikon flybarless system
I finish all the setup buy the book
Stet buy step I chack everything is working
Properly and when I go to the fild on graond
Everything working right go on middle stick
whan I want to lift off its spin like Celine fan
My main rotor spin clockwise and my tail counter clockwise
What should I do to fixed this
please help
Thank you
Hi Eyal
You will have made an error during the setup.
Please start the setup again.
1. Reset the iKON (file, reset)
2. B e certain transmitter controls are working correctly in step 4 of the basic wizard, and do not reverse anything in your transmitter later!
3. Be sure step 8 and 9 are correct
4. Finally confirm everything in step 13
Maybe find an experienced pilot to go over your setup and find the problem....
If it's spinning fast, your tail correction direction is backwards. You will need to change this in the gyro. If I'm not dead tired when I get home, I will post up where you do this unless someone gets to it before me.
Go into the Tail set up menu.
The button in the centre of the menu says Servo Reverse. Click that, then reset the end points for nose Left and right.
Check my video to determine whether your tail is acting correctly.
hello tony I want to thank you
it's work
but I have a wobble my heli is wobble
how can I fix this
some one told me go into advance menu
but I don't know what to do there any help please
thank you
It depends on what kind of wobble you are talking about. Is your tail shaking back and forth? Is the helicopter pitching fore/aft or is it pitching right left?
Sounds like your aileron gain is a little too high. I can't remember how to adjust this, but I know Lee knows. I will learn in the coming weeks though.
I am pretty sure you need to slightly lower your "I Gain" in the gyro. This should stop the wobble. If you can, post up a video so we can see what it's doing. ,
It is raining now so I do it when it stop
and then you can help me solve this issue
Again thank you very much
Hi tony the rain is over and I go chack again and what I find is that I put Sanwa servo and that what cause the heli wobble right and left
I replace the three servos to align ds430m and the heli hovering like charm so what I mean is that ikon flybarless systems don't work with Sanwa servos on 450 size on big heli like 550 ,600,700,800 it's work with ikon flybarless
Interesting. Not sure why they didn't work unless you had the band or hz set wrong for them. Either way, glad you got it working. Now, all we need is a video of it in the air :biggrin:
