Projects Ft Legacy 4s Run Up
Playing Devil's advocate, if your going to use the 6S reverse direction on one motor and put a CW prop on it to minimize the amount of Torque roll.
Looking forward to the maiden video.
I need to buy a Deans to XT60 adaptor!
It's pretty easy to solder one ( or more ) up...
I did a similar one for Deans to EC3 ( both ways ) and didn't even use any wire... just direct soldered them together and then added some shrink wrap around the two connectors. Just make sure to get the polarity correct and you're golden.
Check your ESC's specs and see if it can handle a 6s. If it cannot, then don't hook it up. If it is made for 6s, then the BEC will likely work just fine. If it's not, then it will likely burn up the entire ESC, not just the BEC.
Yup, the mosfets are not made to handle over about 15-16 volts and if you hit them with 25 volts, they release magic smoke.
