Quad First Quad copter Eachine Ex110
hddce
I purchased a ex 110 from bangood with Dsm2 sat receiver. I have a DX6I which is DSMX and can not bind with CLI any help will be appreciated .
Thanks John
Try holding the Tx either very very close to the quad, or at least 6' away. Sometimes these things are wacky.
If you are not able to get into bind mode in CLI (if that is how yours is done. Some you just turn it on until the light starts to flash), then there could be something wrong with your code. Post the code you are using.
That is the correct code for DSM2. And if plugging it in and waiting doesn't give you a bind light, then you may be having the same luck with this quad that I had. Mine is somewhere in the landfill because I couldn't stand the issues that board had.
