General First experience with fpv, using eachine ev007, and walkera f210 drone
Wolf714
Considering upgrade to best TX and rx antennas that I can afford, which will be plug and play. I like the blubeam but are there mushrooms that are just as good? Ive heaRd about the fragility of those wires and don't like.. the mushrooms look like they caN take a few good pops b4 they fail
Suggestions wanted!
Thanks
CWO5 Wolf USMC
RVa
Wolf714
RP-SMA, or SMA ?
Which is compatible with walkera f210 ?
Also, the stock tx has a right angle gold plug which takes cable out/ away from the frame
Do I need that adaptor too, if it's detachable, or do I need a new one and what type/ model # etc ?
Thanks again ;)
Wolf
I have no idea what one it is, you are just going to have to look at the one that you have and match it up on the site. You can also order adapters just in case you are wrong. For instance, you can order the SMA antennas, then order two sma to rpsma adapters just in case. This way you can plug it in no matter what.
