GreekRotorHead
Hi guys, I know that most of the helicopters nowadays run with a fbl head. You have less parts of the rotor to deal with, plus that the flybar you may say that some folks just don't like it. What is the difference between these two options we have relatively to the behavior of the heli? If you add a pair of weights on the flybar you can avoid the affect of a gust during a flight. Which is awesome. All of us sometimes attempt to fly on a low speed wind. But you cannot predict gusts. Can we say that the only difference is that we have a mechanical gyroscope on a fb head and an ''electronic'' gyroscope on a fbl head?
I m wondering if the mechanical set up of the rotorhead is more reliable than the set up of a fbl one. The more electronics you dealing with may be more likely to fail sometime. Now you may say, you have already installed a headlock gyro which uses the same functions with a 3-axis gyro. So what's the difference? Could you guys explain what are the advantages of a fbl head on the helicopter attitude?
