ESC ESC's beep wrong
WyDiablo
My esc's beep on the high side but will not beep on the low side. The ends points on my tx are set at -115 to +115. I only have one esc motor #1 that works and I used it to test the other 3 motors and they will spin from that esc. Kinda weird that they do that I am thinking that they might be shot.
If this is a castle esc start with throttle trim at center and end points at 100. Do the throttle calibration as normal if high does not sound then leave the stick up and add to your end points until it beeps, repeat for low end.
WyDiablo
They were "No name" esc's from ebay and cheap lolol. I would get the normal beeps while in high position but not anything in low position.
