I would like to replace the Emax with the Hired.
Is anyone able to compare the specs below and tell me if the hitec is compatible with the emax?
Thank you
EMAX ES08MD Digital Servo Specifications: - Type: ES08MD - Operating voltage: 4.8V~6.0V - Operating speed: 0.10sec/60º at 4.8V; 0.08sec/60º at 6V - Stall torque: 2.0/2.4 kg.cm 27.8/33.3 oz.in (4.8V/6v) - Dead band: 1 uSec - Gear Material: Metal - Connector wire length: 25 cm - Connector type: Futaba/JR compatible - Size: 32 x 11.5 x 24 mm(1.25 x .45 x .94in) - Weight: 12g / 0.42oz
Hitec HA-5045HB
Control System: +Pulse Width Control 1500usec Neutral Required Pulse: 3-5 Volt Peak to Peak Square Wave Operating Voltage: 4.8 Volts Operating Temperature Range: -20 to 60 Degree C Test Voltage: 4.8 Volts Operating Speed: 0.12 sec/60° at no load Stall Torque: 13.88 oz/in. (1.0kg.cm) Operating Angle: 40° one side pulse traveling 400usec 360 Modifiable: No Direction: Clockwise/Pulse Traveling 1500 to 1900usec Current Drain: 8mA/idle and 100mA no load operating Dead Band Width: 8usec Motor Type: 3 Pole Ferrite Potentiometer Drive: Direct Drive Bearing Type: Ball Bearing Gear Type: AGTT Karbonite Gears Connector Wire Length: 6.29" (160mm) Dimensions: See Schematics Weight: 0.29oz (8.5g)
HITEC RCD USA
Thank you
Hitec HA-5045HB
HITEC RCD USA
