Flight Controllers Eachine Beecore F3 EVO Brushed ACRO Flight Control Board Installation
In this video, I show you how to install the Eachine Beecore F3 EVO Brushed ACRO Flight Control Board into the Eachine E010. It's pretty straight forward, but may help someone in the hobby!
YouTube
While this is not directly related to this thread, it is related to the Eachine Beecore F3 EVO Brushed ACRO Flight Control Board but because it would appear that the thread relating to Spektrum transmitters is down, I thought I'd begin here.
I've been having a discussion with Tony on YouTube in regards to binding the Eachine Beecore F3 EVO Brushed ACRO Flight Control Board to the Spektrum DX9 but nothing I've tried so far including what Tony has suggested has worked.
In order to save typing it all again, I've pasted my last post on YouTube below in the hope that it may ring some bells for those experiencing the issue and can offer some help.
"I'm still doing my head in over getting the darn to work. If it helps any, while my DX9 is telling me the bind is successful, I still don't have any results when moving the throttle stick and the throttle is definitely not locked with the default settings. In your video you mentioned that I should have a solid blue light when I throw the throttle cut switch to it's opposite position but the blue light you alluded to is flashing regardless of what position the switch is in. I even set it up manually with switch A as the throttle cut as I've done numerous times with fixed wing planes. So, on 1 side I have 2 solid red and 2 solid white lights while on the other side I have 1 solid red and the flashing blue a fore mentioned. On the off chance that the default throttle cut switch got switched, (if you'll excuse the pun) I tried throwing all switches but all to no avail. I mentioned earlier that I bought 2 of these at the same time and both are giving me the exact same results so it's unlikely both would be faulty from the factory. In addition, when I plug the interface into my laptop, there is no firmware anywhere to be found but I'm led to believe it's already integrated into the board?. BTW, not that it should make any difference, but I fly mode 1. This is really driving me nuts!"
