To have a sacrificial heli to practice with rather than my Blade 450 I'm in the process of changing the electronics on an E-sky Honey Bee King 4, similar to other 450 type helis, to use my DX6i and an AR6115e Rx. I've followed the videos "DX6i & CCPM etc." and have reached the blade pitch set up. I get +/- 7 on my blades but when I move the throt. lever up and down, idle up mode, I get good rotation (pitch change) on one blade but barely any movement on the other. I can't see why, all the linkages are connected but the movement isn't there. Also I tried to spin up the heli and I don't get any lift. The blades are rotating CW and are installed facing the right direction. The chief difference between the heli used in the videos and the HBK4 is that the flybar is above the main blades.
What am I not doing/seeing??
