Today, is a very good day! It may be raining, it may be chilly, but thanks to @Paulster2, my very first helicopter, the Dynam E-Razor 450 Metal Edition is back home!!! I can't thank you enough for sending this back to me Paul!
As any beginner helicopter, this one has been through its fair share of crashes. I remember the exact time that Paul set it aside after the feathering shaft came apart on it and he purchased the HK450GT. More on that one in another thread. But the Razor is missing a few parts and @Geena, I'm hoping you can help me out.
I have looked at the manual, but that was for the plastic version and you know how Chinese manuals go. So I thought I would ask someone that has another Razor in front of them (potentially).
In the head, I need to know if it is just two radial bearings that are inside the main blade grips, or if there are thrust bearings in there as well? I know I'm missing the two smaller radial bearings that go on the outside of the grips that sit against the head block (with two O-Rings in between that is), but I need to know if there is supposed to be a thrust bearing in there.
If there is not, then that is bad. If there is, then that is bad lol.
My next question for you Geena is, do you have any extra bearings, the small ones? Or do I need to purchase blade grips just to get them? The inside larger bearing is 8x3x3, the one that I need I'm guessing is 6x3x2.5. The bore in the blade grip is 6mm, the feathering shaft is 3mm, and the depth of cut for the OD is about 2.65, but I'm guessing they had it sunk in there a little bit.
Let me know. I don't really want to fly this helicopter, but I do want to get it put back together in flying condition for old time sake lol.
