Spektrum Dx9 Programming Toggle Aux2 On/off
Chopper21
Hi
I have a ducted fan jet and have installed a thrust vector cone on it.
Would like to set toggle switch "E" as a safety disable over Aux2 that is mixed with the Elevator.
Have tried all sorts but no go.
Any advice please
Clynt
I do wish I could help out with this, but I have never played with mixing because I have never needed it. I did try to go into my radio and play with them, but couldn't set up the mix to disable via a switch. I know it is possible, I just don't know how.
Now that I type that, try this... Setup one mix where you want it mixing and on. Then, back out and set up another mix, on the same switch and move where it is activated. I think this might work.
If you can, pull your model out of your Tx and put it in a .zip file and send it to me. I will plug it into my Tx and see if it works since I'm sure what I said above is confusing lol.
Chopper21
Hello Tony
I have managed to get a work around for the problem, there may be a better way but it works fine.
Solution as follows;
Tx DX9
Rx AR8000
Elevator mixed into Aux2 and toggled on or off with switch E
The programming sequence is;
System setup
Channel assign
#7 AUX2 : Aux2
Next
#7 AUX2 : E
(Back)
Digital switch setup
Switch select
Switch E
Was +100% 0% -100%
(Set now) 0% 50% 0%
Channel : Aux2
Channel input config
Aux2 : E
Main screen
Mixing
Mix 1
ELE > AX2
Rate -64% 0%
Offset -75%
Trim Inh
Switch E
(Switch E set) 123 = 010
(back to main)
Cheers
