  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Spektrum Dx9 Charging Issue
Discussion in 'Transmitters & Receivers' started by Blade_flyer, Oct 6, 2017.
< Traxxas TQi Bluetooth issue | Flysky fs-t6 binding compatibilities >
  1. Blade_flyer
    Blade_flyer Member
    Dec 31, 2015
    117
    0
    16
    Jeffersonville, IN
    Home Page:
    I am having an issue with my DX9. I have found it unresponsive too weekends in a row. The first time I thought I may have bumped the power switch and inadvertently drained the battery. I put it on charge and checked it the next day and it displayed 7.4 volts. That was last Sunday.
    Today, it was dead when I tried to turn it on. Once I returned home, I plugged in the charger and the blue light came on. I checked the radio about a half hour later, the blue light was out, and the radio would not power on. I plugged in the charger again, the blue light came on, then went out after 2-3 minutes. I turned the radio on, it was reporting 7.2 volts, but after 20 seconds, it shut off. The radio should stay on even if the battery is at 7.2 volts. The LV alarm is set at the factory default setting of 6.4v. I am running the 2S Li-Ion Spektrum battery.
    Anyone have any ideas?
    Bud
  2. Tony
    Feb 21, 2011
    37,146
    1,458
    113
    Sounds like you have a flat battery. Try taking it out and charging it on an actual charger. I would just put it on a cycle and let it run about 5 times or so and see if it will actually take a charge. If not, then you know it's the battery. If it does discharge and charge about the capacity of the battery, then you know there is something wrong inside the tx.
  3. Blade_flyer
    Blade_flyer Member
    Dec 31, 2015
    117
    0
    16
    Jeffersonville, IN
    Home Page:
    That is the issue. I took the battery apart and found one of the cells dead and it had a discharge at the positive post. Time for a new one.
  4. ChopDrifter
    ChopDrifter Member
    Sep 2, 2017
    239
    6
    18
    Gender:
    Male
    NZ
    I use a bigger battery that I purchased on Ebay. It's been working well on my DX9. I never used the stock battery that it came with at all, which I flattened it and dispose of it.
  5. ChopDrifter
    ChopDrifter Member
    Sep 2, 2017
    239
    6
    18
    Gender:
    Male
    NZ
    Here's a picture of it. damn typo
  6. ChopDrifter
    ChopDrifter Member
    Sep 2, 2017
    239
    6
    18
    Gender:
    Male
    NZ
    Talk about DX9 Charger, did you find your charger?
  7. Tony
    Feb 21, 2011
    37,146
    1,458
    113
    Yes I did. Had to for the 450 videos lol.
Share This Page
