Spektrum DX9 brain fart
fran11784
Spoken flight mode default is "stunt 1,2,3" I want it to say "Idle up 1,2,3" When I set it up she speakes "stunt 1 idle up 1" How do I get rid of the "stunt 1" and get it to say "idle up 1" only?
pvolcko
Did you use a custom voice setup for this, or did you modify the voice prompt for flight mode in the system setup menu for that model?
Get rid of the custom voice setup for this, if you did that. Go into the system setup menu for the model, then select "spoken Flight mode" and change it there.
fran11784
OK got it. Used custom voice setup. Ive done it on other models but couldn't remember. Thanks again Paul....
T
