  2. Hey Guest, are you here looking for the PDF Plans? They are located in the store in the tab above, but you must be signed in to access that part of the site. It only takes a second to sign up!
Dx8 Phoenix 5.5 Switches
Discussion in 'Paid Simulators' started by Ronald Kessler, Nov 17, 2017.
  1. Ronald Kessler
    Ronald Kessler Member
    Blog Posts:
    0
    Aug 29, 2017
    124
    4
    18
    Gender:
    Male
    San leandro
    I seen the videos with RealFlight but how do I get my switches F mode and Gyro to work on my DX8 with the Phoenix 5.5. I'm trying to play with gyro gains to learn about a real helicopters gyro but it's not working
  2. Geena
    Geena Moderator Staff Member
    Blog Posts:
    0
    Feb 3, 2017
    584
    48
    28
    Gender:
    Female
    Occupation:
    Certified Aircraft Welder
    Sebring, Florida
    You set the switches up as you normally would for your flight modes, throttle hold, and gyro gains. But they won`t have any affect on the helicopters in the simulator. You`ll have to adjust the simulator models in the model edit menu in Phoenix.
  3. johncblacker
    johncblacker Member
    Blog Posts:
    0
    Feb 23, 2014
    30
    8
    8
    Ocala, Florida
    You have full access to the switches if you go into the file -> control menu. You can set those to defaults and just use the setup that's already in your tx.
  4. johncblacker
    johncblacker Member
    Blog Posts:
    0
    Feb 23, 2014
    30
    8
    8
    Ocala, Florida
    If you choose to use the "control edit" section, you'll have to know which switch controls which "aux" port. You should be able to find that info quite easily online.
Share This Page
