  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Spektrum DX8 How To Articles & Videos
Discussion in 'Transmitters & Receivers' started by Tony, Jan 3, 2015.
< Post Your DX8 Files | DX9 How To Articles & Videos >
  1. Tony
    Feb 21, 2011
    36,667
    1,412
    113
    Below is the link to all of Rc-Helps DX8 videos. If you can think of any videos that you would like to see, post them up and I will get them made.
    Rc-Help - Spektrum DX8
  2. DMartin_nj
    DMartin_nj New Member
    Mar 28, 2017
    24
    0
    1
    Gender:
    Male
    Occupation:
    Transit Technician
    New Jersey, U.S.A.
    This link does not work, it's broken.
  3. Tony
    Feb 21, 2011
    36,667
    1,412
    113
    My apologies, I have updated the link to the correct one.
  4. bassslayer1960
    bassslayer1960 Member
    Feb 27, 2016
    58
    3
    8
    Gender:
    Male
    Me.
    Hey Tony,
    How about a video on setting up the switches on a DX8G2?
    I am not understanding switch assignment, channel assignment or %'s.
    Thanks again, Robert
    flaper and Buckshot like this.
  5. Tony
    Feb 21, 2011
    36,667
    1,412
    113
    I think I have went through that with the DX9. The DX8 G2 and the DX9 share a lot of features and are almost identical. Have a look at the DX9 videos and see if that answers your questions. I don't have a DX8 G2, but if a video needs to be made, I can make it with the DX9. Just let me know.
  6. bassslayer1960
    Feb 27, 2016
    58
    3
    8
    Gender:
    Male
    Me.
    I dont know what setting options are available for the DX9(G2).
    I have allready watched both series of vid's( DX8& DX9).
    Although very good and informational, the info I seek is not there.
    I want to try your 9 flight mode setup specifically.
    I am trying to setup a trex 450 sporting a AR7210BX, Scorpion 1880kv sporting a Castle lite 100 with white wire as RPM out.
    This is my first setup on my new DX8G2.
  7. Tony
    Feb 21, 2011
    36,667
    1,412
    113
    There is only one DX9. The firmware is exactly the same as the DX8 G2 though, just with an extra channel.
    Below is a video on basic helicopter setup with the DX9, which is exactly the same as you would setup your DX8 G2. As for the gyro setup, below that is a video on the AR7200BX setup which will translate over as well. Hope this helps.
  8. Randyscotty
    Randyscotty New Member
    Aug 28, 2017
    13
    1
    3
    Gender:
    Male
    Us
    Hello Tony, my name is Randy. New to The Forum good job bro. Anyways, it says post inquiries and you can possibly make a video in regards to it. Well here's the Dilemma that I've yet to see ask of you. I have a DX8, and I wish to program it into a Tamiya type scratch-built truck. I've seen plenty of other videos and regards to dx6 and so forth. Would like to do certain things, you sticks a certain way, just wondering think you can come up with something. Thanks
  9. Tony
    Feb 21, 2011
    36,667
    1,412
    113
    Create a thread in the car and truck section and let us know what equipment you will be using. I know you are using a DX8, but what Rx, what motor and ESC (unless nitro or gas), what servos and what functions you want the truck to have. Once I have a better understanding of exactly what you are trying to build, I may be able to make a video to help out (with a DX9, but could get a DX8 if it is absolutely necessary). Can't wait to see your post, and thank you for the suggestion. Hope I can come up with something good.
  10. rdsok
    rdsok Well-Known Member
    Sep 11, 2011
    1,655
    60
    48
    Norman, Ok USA
  11. Randyscotty
    Aug 28, 2017
    13
    1
    3
    Gender:
    Male
    Us
    Tnks rdsok.... I was just getting ready to reply back to Tony.
    rdsok likes this.
  12. Randyscotty
    Aug 28, 2017
    13
    1
    3
    Gender:
    Male
    Us
  13. Randyscotty
    Aug 28, 2017
    13
    1
    3
    Gender:
    Male
    Us
    Tony, I have a DX8 Gen 2 transmitter, I have an AR 8110 t receiver. Standard Tamiya motor brushed, with a dynamite 60 a waterproof forward reverse brushed electronic speed controller Horizon Hobbies.savox servo for steering. Not too much concerned about multiple functions at the moment, the problem in lies with the fact that I cannot get dual Direction out of my motor. Meaning if I push the stick forward the wheels go forward if I pull the stick back the wheels go forward, and vice versa if I invert the program or change the leads on the motor. I've done a model reset, have even tried different modes, I have switched sticks around and even switch stick functions, regardless of what I try I have the same results.
  14. Tony
    Feb 21, 2011
    36,667
    1,412
    113
    Ah copy that. I will try to check it out tomorrow and see what I can do. Had a few minutes to spare tonight and thought I would catch up a bit on here. Things are about to change though. Hopefully for the better.
  15. Randyscotty
    Aug 28, 2017
    13
    1
    3
    Gender:
    Male
    Us
  16. Randyscotty
    Aug 28, 2017
    13
    1
    3
    Gender:
    Male
    Us
    I appreciate your response toting so rare do you go to forums and find Edmunds that actually get involved within their site and their members. Thank you
  17. Tony
    Feb 21, 2011
    36,667
    1,412
    113
    You will need to set your DX8 so that the throttle centers. You can do it without taking the case apart, but might be easier to take the back off the Tx so you can see what you are doing. Basically just mirror the elevator setup with the spring. Then, you will need to calibrate your ESC to the Tx so that it knows where N is as well as F and R. If you don't have any luck, I will try and read though the manual of the ESC and possibly borrow a DX8 so that I can show you what I'm talking about.
    And I love helping people, that is why I created this site. Just give me a bit of time and I will see what I can get done in helping with your issue. At this time, it's time to hit the sack and deliver this load first thing in the morning.
  18. Randyscotty
    Aug 28, 2017
    13
    1
    3
    Gender:
    Male
    Us
    Good night brother man sleep well
  19. Randyscotty
    Aug 28, 2017
    13
    1
    3
    Gender:
    Male
    Us
    And not to be a pain in the ass, but I have spent the last couple of days on the phone with Horizon Hobbies they claimed to have duplicated my setup and had gotten it to work, I'm just perplexed.
  20. Tony
    Feb 21, 2011
    36,667
    1,412
    113
    If they sent you a set of settings, post them here so that I can see them. I will reply to this tomorrow so that it is in my new feed and I don't forget. But if I do, just post up and bump it up. It's been known to happen a time or two lmao.
Share This Page
