To clear out the models, it's actually pretty easy. Push and hold the top of the roller (always put the top, never the bottom) and turn the Tx on. Select the model that you want to clear out then scroll down to clear model or something along those lines (my Tx is out in the office and I'm in the house). That will clear the model out.
Now moving the models is a little harder, however, this is the easiest way.
Once you are done clearing out models 1-7, go to the model you want to move and select it. From there, in teh same menu as the Tx turned on in, you will scroll down to Copy Model. In there, you will tell it to copy the model to the spot where you want it. after that, just delete the original model and you are good to go.
Hope this helps.
