First, make sure your right aileron servo (right wing looking from the rear to front) is plugged into your Ail port on the Rx. Left wing will be plugged into the Aux1 port. Make sure you are setup on dual ailerons in the wing menu. In the flaps menu, you will go from INH to Flaperons. Make sure to NOT add too much angle for your first flight. Only about 10º MAX to test. If you put in 10 into the flaps, then put 1 into the elevator. You want UP elevator, NOT DOWN. It will want to nose to the ground when you deploy flaps so you need up elevator to counter it. You will have to play with the settings until you get what you are looking for.
As stated, it's best to just use dedicated flaps, but flaperons will work if you set them up correctly. Good luck and let us know how it works.
