tricky1400
hi last year I fitted a new backlight to my dx6i , after fitting it I obviously checked the backlight worked but at the time I didn't fly either of my helis used on that radio .
over the weekend thought I would have a go and when I tried to use the cyclic switch ( mode 2 right hand thumb pushing back and forward ) nothing happened , tried it on the second heli and again no servo movement .
the left and right movement is ok , everything works there and with the other stick throttle and rudder work ok , its just the cyclic not working
is it coincidence that this suddenly packed up when I fitted the backlight ?
I have unplugged two of the wires to the motor to try and find the fault without the blades turning ( don't think this makes any difference ) and taken the back off of the radio to see if there are any wires not plugged in but all looks ok .
could I unplug the cyclic block from the board and swap it over somewhere not sure which one to try to see if its the switch or the wiring / wiring block ? by using the other stick to do the cyclic or use the same stick to do the cyclic but have it working when I move the stick right to left ?
( then obviously change it back when I have identified the fault )
thanks for any help
I don't have any multimeters etc to test for electrical problems
not sure if I could buy internal spares for the radio in the UK ?
thanks
thanks for any help
thanks
