Tony submitted a new Article:
Dx6i & Ccpm Full Setup Guide Part 2 Installing Servos & Wiring The Rx
Hello everyone. If there is one questions or suggestion that I get asked more than anything else, it's "can you make a "how to" video that covers everything from start to finish?". Well, that is exactly what I have done.
This series is going to show you exactly what to do to setup your DX6i, set all your swash, pitch, throttle curves, gyro settings, end point's, and everything else in the radio. Then, I'm going to show you exactly how to bind the Tx to the Rx. Then, setup all fo the servos on the cyclic, adjust all the links to get the proper swash height so you get the same pitch up as you do down, set the blade tracking, setup the gyro outside while hovering and getting the swash correct for FF or forward flight.
So, sit back and enjoy this series. I will also try to get the WHOLE series on my website so that you can download it, and watch it anywhere you have a computer. No internet required after the download.
In this video, I go through installing the servos, what servos I have, and how to mount them. Also, what motor I'm running. Then, I show you how to run all of your wires, and get ALL of them plugged into the Rx. Then I show you how to install the gyro, and run those wires. In the next video, it's binding the Tx to the Rx and a whole lot more. So, please subscribe so you don't miss out on anything.
