Hello all,
Having an issue with my bind on a dynam E Razor 450. I have replaced the receiver with the spek AR6210 and got the dx6i. I have followed all of Tony's youtube vids on the setup. Everything is replicated from Tonys settings. The problem is once I turn the radio on then plug batt in I get the initial beeps, then I get the constant beeping from I think the ESC. It does not stop beeping so I unplug batt and try it again and it does same thing. I then tried clicking the throttle hold towards me and and would start to spool up. Also if you hit the throttle cut button it will spool up!
Hopefully I can get some help on this issue..
Thanks
Thanks
